converting DVD into editable format
Marten
on Jan 7, 2006 at 8:51:39 pm
Hi, its Marten from Barcelona, i need to convert a DVD into a format that i can import into Final Cut. This is for a documentary on the early days of surfing in south east asia... Thanks a lot if someone mght be able to help.
Charles Simonson
Re: converting DVD into editable format
on Jan 9, 2006 at 1:16:16 am
Try using MPEG StreamClip. Many options and very fast.
Mike Cohen
on Jan 11, 2006 at 11:52:59 pm
sub the DVD to DVCAM or whatever tape format you use, then digitize it the usual way.
Charles Simonson
on Jan 12, 2006 at 3:13:33 am
The problem with that is that most DVDs are progressive, and most DV cameras are interlaced, so you would introduce a significant loss in quality with that method.
