Best footage to test encoders ?
Pierre-Luc
on Dec 19, 2005 at 4:22:04 pm
What would be a good video sequence to test software/hardware mpeg-2 encoders ? Action, high contrast, brights colors, many cuts ?
Pete
Don't fear the tiger, the Cow is near!
Charles Simonson
Re: Best footage to test encoders ?
on Dec 20, 2005 at 8:14:27 pm
I would suggest all of the above if you are planning to encode that type of video. Also, testing interlaced and progressive source if necessary is good.
Ben Waggoner
on Dec 30, 2005 at 10:39:07 pm
And if you're testing for a particular application, nothing beats testing the kind of content you're expecting to use as source. The closer your test source is to what you want to use, the better.
