How big is too big?
jeremy
How big is too big?
on Dec 15, 2005 at 4:40:03 pm
Yeah, I know it's kind of an open ended question. There are many factors such as internet connection speed, etc. However, generally speaking what is too big of a file in WMV. I've compressed a video that is 18 minutes long to be played back from my website in WMV and the total size is 178 MB. Do you recommend I lower my setting and drop the file size?
Thanks for any help.
Jeremy
Craig Seeman
Re: How big is too big?
on Dec 15, 2005 at 4:54:04 pm
If you're coming from an http server (progressive download), break it in to smaller chunks otherwise people will have long waits while enough file buffers to play. If people can't sit through the whole thing they'll have to start over again on the next visit. I'd break it in to three parts. I finde a data rate range of 300kpbs to 800 kbps reasonable depending on the the typical DSL/Cable speeds in the area you target. File size is important if you're nearing your size alotment or monthly throughput limit.
jeremy
on Dec 15, 2005 at 5:08:23 pm
Hey, thanks for the advice. I'll try breaking it up into parts.
Jeremy
