mov to mpeg
uwishbiff
mov to mpeg
on Dec 14, 2005 at 12:21:08 am
I'm looking for an app to convert a mov to a mpeg-1 file...I know that its possible using Cleaner. Unfortunately, I don't have a copy of Cleaner. I do however have FCP and Compressor. Maybe there is a free solution to this or maybe its something i'm overlooking that I might be able to do with my existing software.
Thanks to anyone who might be able to offer any help!
uwishbiff
phil
Re: mov to mpeg
by
on Dec 14, 2005 at 3:34:30 pm
yes, compressor allows you to export out using mpeg 1...in the apple presets, the MPEG-1 DVD 1.85 will give you an extensino of .m1v, so just make a new custom one, that has the extension .mpg
thats it!
Charles Simonson
Re: mov to mpeg
on Dec 21, 2005 at 12:09:37 am
I don't believe some versions of Compressor will mux MPEG-1. I think 1.2.1 did, but versions prior to that could not. If for some reason you are forced to use an earlier version, and can only output elementary MPEG-1 streams, then I'd recommend BitVice Helper or MPEG StreamClip (both free). There is also ffmpegX ($15) which will do a better job encoding the video to MPEG-1 than Compressor. But it can be difficult to use for some.
