AVI codec for Cleaner XL
Olle Eriksen
on Dec 13, 2005 at 8:55:05 am
We are brushing up an old Multimedia project (CD-ROM) and want to replace the video content. The old video is coded with Microsoft MPEG4-V2. This codec is not available in our Win Cleaner XL (can I get it somewhere?).
Is there any other (better) codec to use? We have to use the file extension .avi to avoid reprogramming.
Olle
Charles Simonson
Re: AVI codec for Cleaner XL
on Dec 21, 2005 at 12:23:02 am
There are definitely much better codecs to use than MS MPEG-4v2. Windows Media 7,8, or 9 are better options, but I am not sure of compatibility in an AVI wrapper (I think v7 and 8 will be fine). Probably the best bet is to encode using either the DivX 5 or XviD codecs. You just have to make sure that the end user has either decoder installed. If you don't want to worry about that, then I would suggest you reinstall Cleaner and see if it "shows" up again.
