2k cinema playback from Powerbook to projector
Tom Ackroyd
on Nov 26, 2005 at 7:40:32 am
I have a 30sec cinema spot sitting on my G5 as an uncompressed quicktime at 2k resolution. (In fact it's a 1:2.35 ratio spot at 1828x777 pixels.)
I'd like to play this from a recent decent Powerbook through a data projector at highest possible resolution with no dropped frames.
Can anyone advise best compression for this? I guess I'll need to shrink the picture size - at the moment I don't know the maximum resolution our projectors can take, and also do not know native res of the biggest screen Powerbooks.
So really my main question really is what is a good datarate to aim for?
Sorry for the lack of knowledge and unknowns in this - I am investigating MJPEG but would appreciate any comments. I've never worked at this size before.
Thanks in advance,
Tom Ackroyd
Tom Ackroyd
Re: 2k cinema playback from Powerbook to projector
on Nov 26, 2005 at 7:41:16 am
I should mention that I don't have QuickTime 7 and so cannot use H.264.
Cheers,
Tom
Ben Waggoner
on Dec 10, 2005 at 7:46:37 pm
Your best bet might be MPEG-2 playing out via FLC 0.8.4. However the G4 processor in PowerBooks today are pretty anemic for HD playback. Could you use a Wintel box, or maybe DVI out of a iMac G5 17"?
Tom Ackroyd
on Dec 11, 2005 at 9:23:16 pm
Thanks Ben.
Wintel playback not really an option.
Could you explain exactly what FLC is?
If I'm playing back MPEG-2 I would presumably need the QuickTime MPEG-2 component installed?
I've had some success with mpeg-4, but am certain quality could be improved.
Your iMac suggestion is good - would you recommend H.264 for this if MPEG-2 isn't an option?
Sorry for all the new questions!
Cheers,
Tom Ackroyd
Tom Ackroyd
on Dec 13, 2005 at 8:51:06 pm
It's all over. And for those that are ineterested:
I did the playout yesterday from a G4 Powerbook, QuickTime 7, to a data projector via RGB not DVI. Projector res was only 1024 wide - this is what I set the Powerbook res to.
The codec I ended up using was (fanfare) Sorenson3 (not Pro, just the one that comes with QuickTime) using Compression Master; datarate disabled, Sorenson setting "high", (maximum quality caused dropped frames.) I had prepped a 1280x544 uncompressed version of the spot, having downsized the original 1920x777 tiff sequence in Photoshop, and got the codec to do the shrink to 1024 wide - an odd workflow I know but ran out of time...
I had already tried H264 but Sorenson was just way better. Maybe it's down to datarate I don't know.
So, the compromises were:
Not 2K
Not DVI
Old projector
But results still good and it demo'd the spot reasonably well.
Off to the cinema now to see it in real life.
Ben - still keen to know about FLC...
Cheers,
Tom Ackroyd
