mpeg1 is pixalated on tv monitor
Zeliha
on Nov 25, 2005 at 11:32:29 am
Hi everyone!
First of all I have to say that I am very new to the worl of compression.
I need to create a PC compatable MPEG of my 50 minute sequence, to be used as a video reference in a pc based dubbing suite.
I am using FCP5 version 5.02. I created an MPEG file using: MPEG 1, under New Default Settings in the Compressor. The Dubbing Mixer could open this file but when he watched it thorugh the Tv monitor the quality was reduced alot.
Also, this Mpeg took 3 hours to create and it was around 800mb.
Is there an alternative? Can anybody help please.
PS. The Dubbing suite cant play Quick Time files :(
Zee :)
mike velte
Re: mpeg1 is pixalated on tv monitor
on Nov 26, 2005 at 1:02:56 pm
Mpeg 1 is a very poor option for video projected on a TV, but you could improve things some by encoding at 2 mbps which is almost double your current settings. For DVD quality you should use Mpeg 2 at about 6 mbps, but you will need to install a Mpeg 2 decoder (software player) on the playback system.
