Problems Encoding 5.1 AAC Quicktime
Matthew Keane
on Nov 6, 2005 at 1:39:14 pm
Hello,
I seem to have hit a problem encoding a h.264 Quicktime with 5.1 AAC audio. The video is fine, but I seem to end up with missing, or empty, audio tracks in the resulting quicktime. The audio files are 6 individual WAV files supplied by the recording studio.
First attempts were exported via compressor from Final Cut Pro with the AIFF audio tracks layed out on 6 audio tracks. The audio amp connected via the optical out on the G5 showed only two tracks, which was confirmed when I soloed each track in Quicktime. Although the file info shows 6 tracks, only the first two tracks contained audio, the other four tracks were empty.
Since I also want to output a WMV with 5.1 audio using Flip4Mac, I followed the instructions on their site and prepared a Soundtrack Pro project with the 6 audio tracks and assigned them to the appropriate channels in the compressor export option. I set it crunching and the result was again a Quicktime with AAC audio containing 2 good channels and 4 empty channels. The WMV export showed only 2 channels in the file info in the player.
If I take the same audio files and export to an ac3 file, either in Compressor, or using the Soundtrack Pro project, I get a 5.1 audio file just as I want, and all the tracks are recognized by the audio amp. So, any ideas where I'm going wrong with the AAC output? Have I forgotten to check a hidden 'make it work, dammit' option?
Matthew
