alternate compression options..?
pixel8ted
on Oct 30, 2005 at 2:07:33 pm
Hi guys,
I am planning to upload some stock footage for sale online as single downloadable clips, the most preferred compression codec for cg stock footage, is quicktime png, but I find that some clips dont seem to compress down to acceptable file size limits with this codec, I get file sizes in the range of 120MB (even after compression), could anyone suggest some alternate codec which will compress it down to atleast 80 MB range?
The clips I am compressing are PALNTSC (720x576/720x486),25/30 fps, duration around 10 seconds.
please advice.
thanks.
Ben Waggoner
Re: alternate compression options..?
on Oct 31, 2005 at 4:27:01 pm
I prefer Motion JPEG B for stock video, especially if it is interlaced. PNG is RGB 4:4:4 lossless, so it 's great for progressive graphics, but lousy compression for interlaced with video source.
My Book: http://www.benwaggoner.com/books.htm
Squeeze and ProCoder tutorials: http://www.classondemand.net/benwaggoner/
Compression Class at Stanford: http://www.digitalmediaacademy.org/compression.html
pixel8ted
on Oct 31, 2005 at 5:00:55 pm
Hi Ben,
Thanks for your reply, but most of it is cg and not interlaced video...
Ben Waggoner
on Oct 31, 2005 at 5:07:23 pm
Ah, CG normally does quite well with PNG.
Are you in "Best" mode?
pixel8ted
on Nov 2, 2005 at 10:13:31 am
I am compressing from after affects, and i have set the compression to best.
Gen Kiyooka
on Nov 4, 2005 at 6:03:04 pm
My suggestion is Apple Pixlet which comes out of Pixar where CG is all they wrote.
Gen Kiyooka
Digigami
