Squeeze 4.1 and FCPro
David Coffin
on Oct 27, 2005 at 10:04:15 pm
Brand-new to using Squeeze (and FC, for that matter...)
So far, every time I try to use Squeeze, it crashes at 50% complete; just stops and have to force quit. On G5, 10.4; dragged QT file exported from FC into Squeeze window, appplied QT CD preset, hit go button...fails at 50%.
Any suggestions? (Already wrote to Sorenson, and noted several unanswered similar queries in their forum...:(
dc
Craig Seeman
Re: Squeeze 4.1 and FCPro
on Oct 28, 2005 at 2:09:40 am
What format file are you exporting from FCP? DV as mov or ?
David Coffin
on Oct 28, 2005 at 2:34:37 am
I
Craig Seeman
on Oct 28, 2005 at 3:51:27 am
QT Movie BUT is your source a DV NTSC timeline or . . . ?
Is your move Self Contained or Reference?
David Coffin
on Oct 28, 2005 at 8:33:32 am
DV NTSC in the Timeline, yes...and tried both self-contained and ref exports.
Craig Seeman
on Oct 28, 2005 at 7:01:43 pm
I've seen that strange problem where you have to drag in the file to Squeeze. I haven't had the crashing though using the CD preset though.
Try the following:
Repair Disk Permissions
Toss Squeeze Preferences
Export from FCP as Self Contained
Playback self contained movie in Quicktime first and make sure that file is without issues.
Then place in Squeeze.
Sorenson Squeeze 4.2 for Mac should be going into Beta soon so we should make sure they hear about repeatable issues and check that they've been solved in the beta.
Post Man
on Dec 16, 2005 at 12:23:41 am
when you export from FCP, try adding .mov to the name.
This MAY help Squeeze recognise the file for importing, without having to drag it in.
Craig Seeman
on Dec 16, 2005 at 3:20:18 am
Add .mov to the file allows one to import file into Squeeze without dragging. Although it's a bit of a drag to have to do that.
