compressing 30 minute video for CD delivery
roseberrye
on Oct 8, 2005 at 1:32:05 am
We have about 1/2 hour of video clips that need to be delivered on a CD for playback embedded in Powerpoint slides to run in WindowsXP. What's the best way to compress the video to fit into 630 mb availible?
Thanks.
Barry
Charles Simonson
Re: compressing 30 minute video for CD delivery
on Oct 13, 2005 at 12:04:49 am
You probably want to use either MPEG-1 at 352x240 or 352x480 progressive, or Windows Media 9 at 640x480. In both cases you could encode to a max of 2.5mbps and fit all of the video on the CD with the video still looking good and playing back in Powerpoint.
Mochegod
on Oct 13, 2005 at 4:38:43 am
Charles, wouldn't you want to encode at 320x240 for playback on a computer monitor (square pixels)? I always thought 352x240 was for VCD.
Charles Simonson
on Oct 13, 2005 at 8:53:01 pm
Most software will recognize the 4:3 flags and display the 352x240 MPEG-1 at 320x240. I am not 100% positive that Powerpoint will, but if it didn't, then yes, encode to a square pixel size format.
Ben Waggoner
on Oct 21, 2005 at 5:11:01 pm
WMP before v9, and DirectShow/VfW implementations of that era couldn't do non-square-pixel correctly, which is why square pixel MPEG-1 is so emphasized. Less of an issue today, although there isn't any real reason to encode at anything other than the final frame size.
My Book: http://www.benwaggoner.com/books.htm
Squeeze and ProCoder tutorials: http://www.classondemand.net/benwaggoner/
Compression Class at Stanford: http://www.digitalmediaacademy.org/compression.html
