360x270 video using Cleaner?
on Oct 6, 2005 at 8:39:55 pm
I'm sure I'm missing out on an obvious answer to this problem, and it probably involves math (not my strength) so I'm turning to you all who can probably answer this very easily. I've got some 4x3 video exported from FCP that I'm compressing. Using cleaner with the Sorenson 3 codec I have no problems making clips 320x240. The problem is my boss would like the clips to be 360x270 so that the height would be the same as the 16x9 clips we compress at 480x270. When I attempt this I get unviewable diagonal lines. So can anyone help me either make 360x270 video or explain to me in a way that my boss would believe why this is not possible?
Thanks in advance,
Re: 360x270 video using Cleaner?
on Oct 7, 2005 at 3:11:39 pm
Not sure if Cleaner or FCP allow you to scale your video to that resolution, or which application used to set those dimensions. And although it is optimal to scale in halves (640,320,160...480,240,180), I don't understand why it would look THAT bad. Squeeze lets you do whatever dimensions you want. After Effects too.
© 2018 All Rights Reserved
