FCP5 HDV to Sorenson 3 Quicktime via CM 3.1.2
twistlick
on Oct 2, 2005 at 5:01:50 pm
I've got a Sony HDV camera and I'm trying to compress some shots that I loaded into FCP5 down to quicktime movies (Sorenson 3 codec) using CM3.1.2. The movies turn out stuttering, one frame forward, two frames back, 3 frames forward etc. I've exported the files out of FCP5 as QT reference movies and also tried the original HDV quicktime but the same thing happens. I assume it has to do with the MPEG compression of HDV but how can I compress smooth playing quicktimes from HDV? Any suggestions?
Ben Waggoner
Re: FCP5 HDV to Sorenson 3 Quicktime via CM 3.1.2
on Oct 3, 2005 at 6:25:24 pm
Sounds like you've flagged the field order wrong in the deinterlace field. Try switching from/to upper/lower.
I honestly haven't tested HDV with CM 3.1.2 yet, so I'm not sure what caveats there are for it.
