NTSC to PAL ?
raukouy
NTSC to PAL ?
on Sep 25, 2005 at 8:49:10 pm
I need to convert a DV Stream or QT movie from DV-NTSC to DV-PAL. I have Compressor 2 and Cleaner 6, I tried just applying a PAL setting to the NTSC file and both apps convert it, but the result is kinda shaky, like it was deinterlaced or something.
Any tips on the best way (settings) to convert NTS to PAL ?
Ben Waggoner
Re: NTSC to PAL ?
on Sep 26, 2005 at 11:06:36 pm
With Compressor 2, you'll want to go into the Advanced Format Conversion presets, apply an appropriate preset, and then turn on the Frame Control features. Automatic isn't a bad choice. But if you want to burn a LOT of CPU cycles for max quality, you'll want something like:
Resize: Best
Output Fields: Same as source
Deinterlace: Best
Adapative Details on
Rate conversion: Best
I haven't really gotten my head around Anti-alias and Details in practice yet. 0 for both seems to work reasonable well.
My Book: http://www.benwaggoner.com/books.htm
Squeeze and ProCoder tutorials: http://www.classondemand.net/benwaggoner/
Compression Class at Stanford: http://www.digitalmediaacademy.org/compression.html
