Compressor
David Battistella
Compressor
on Sep 22, 2005 at 6:19:52 pm
Searched the archives but could not turn anything up on this.
Is there an easy way to apply a setting to multiple clips in compressor. I have about 60 clips to compres and I want to same setting for all of them and I can not seem to find an easy way to do this. I also want to "batch change the destinaiton" and that is a one by one as well.
Thanks in advance.
David
Ben Waggoner
Re: Compressor
on Sep 23, 2005 at 5:23:50 pm
Just select all the clips, and then select the setting you want to use from the Setting menu.
My Book: http://www.benwaggoner.com/books.htm
Squeeze and ProCoder tutorials: http://www.classondemand.net/benwaggoner/
Compression Class at Stanford: http://www.digitalmediaacademy.org/compression.html
David Battistella
Re: Compressor
on Sep 27, 2005 at 9:05:33 pm
I was trying to drag and drop. duh?
David
