Which Software App./Encoder/Platform Should I be using if...
Aaron
on Sep 20, 2005 at 6:20:20 pm
I am encoding a Qtime File out of FCP and I need to make it a 1280x720p wmv10 file with a 7-10MB variable bit rate. Any suggestions on what software app/encoder I should be using.
Any suggestions would be helpful thanks,
-Aaron
Ben Waggoner
Re: Which Software App./Encoder/Platform Should I be using if...
on Sep 20, 2005 at 7:46:48 pm
For that, you'll want either ProCoder or Carbon. It supports reading QuickTime files, and outputting with WMV9-AP using the WM SDK 9.5. WME won't read your QuickTime source.
If you're using the DVCPRO-HD codec, only the high-end Carbon will work - AFAIK, it's the only DVCPRO-HD decoder on Windows in a compression tool.
http://www.rhozet.com
My Book: http://www.benwaggoner.com/books.htm
Squeeze and ProCoder tutorials: http://www.classondemand.net/benwaggoner/
Compression Class at Stanford: http://www.digitalmediaacademy.org/compression.html
