Final audio out of sync when using compressor
paldesy
on Sep 19, 2005 at 12:32:17 am
Hi
When i compress i file in compressor from FCP the audio jumps out of sync when i look at it in DVD Studio Pro. I thought it might have been when i was doing a quick test with a faster compression however when i increased the quality it was still out of sync.
If there are any ideas on how to fix this it would be greatly appreciated.
Paul : )
Aaron
Re: Final audio out of sync when using compressor
on Sep 20, 2005 at 6:23:16 pm
Have you run DVDSP in simulation mode or are you playing it out of the DVDSP sequence? Have you tried doing a sample build and previewing prior to burn with DVD Player?
-Aaron
paldesy
on Sep 21, 2005 at 5:26:39 am
yeh i have tried it in simulation mode and the audio is out of sync when i look at it there too. The final product is also out of sync when played on a DVD player. I am not sure whether it is something i am doing in DVDSP or whether it is when i actually compress it that it is losing sync. When i export from FCP i run Compressor and just use the generic 60min High Quality Setting to compress it.
