Cleaner's Flash update
John Farrell
on Aug 22, 2005 at 6:21:33 pm
Has anyone had any experience with this:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=5585724&li...
Cleaner has apparently made a settings available for output to work with Flash. But it's not clear from the note whether it means you can output .flv files, or just QuickTime movies that work more nicely with MX 2004 Pro.
John Farrell
"Digital Movies With QuickTime Pro"
http://www.charlesriver.com/titles/digitalmoviesQT.html
Ben Waggoner
Re: Cleaner's Flash update
on Aug 25, 2005 at 5:34:26 pm
It uses Macromedia's QuickTime Export Component for making .FLV files.
AFAIK, it's the same one that's been up for a year or so ago. One of the last things Hage Van Dijk did before he turned out the lights and shut the door.
My Book: http://www.benwaggoner.com/books.htm
Squeeze and ProCoder tutorials: http://www.classondemand.net/benwaggoner/
Compression Class at Stanford: http://www.digitalmediaacademy.org/compression.html
