Using Compressor I need mpeg2 with audio & video in same file.
Juan Francisco
on Aug 21, 2005 at 7:46:17 pm
HI,
I can't see where I can set up Compressor1 to make a mepg2 file with audio and video as parrt of the same file.
Juan.
Craig Seeman
Re: Using Compressor I need mpeg2 with audio & video in same file.
on Aug 22, 2005 at 11:55:28 am
Haven't tried it myself but in Compressor 2 in the Inspector under Encoder/Extras Tab there's a "Multiplexed MPEG-1/Layer 2 Audio" check box with the discription "Select this to create an MPEG-2 Trasnport stream with multiplexed audio.
Juan Francisco
on Aug 22, 2005 at 11:29:37 pm
Could you be more specific. I have 2 separate files that i need to compress and combine for DVD studio pro. One file is a .m2v file and the other is an aiff file. Please, if you could help, that would be great. thanks
Juan
Charles Simonson
on Aug 23, 2005 at 4:25:21 am
Check out either ffmpegX or BitVice Helper.
http://www.innobits.se/pubdown/BitViceHelper.sit
http://homepage.mac.com/major4/
Juan Francisco
on Aug 22, 2005 at 11:37:03 pm
and i'm using compressor 1.
Craig Seeman
on Aug 23, 2005 at 3:16:20 am
I don't think Compressor 1 could mux mpeg2. One more reason to upgrade. Compressor 2 is a major improvement over Compresson 1 IMHO.
lukeinvt
on Aug 24, 2005 at 10:35:12 pm
Why? As far as I know DVDSP would prefer that you import your video and audio files seperatly. If they share the same file name (example.m2v and example.aiff) DVDSP will know that these 2 files are linked.
Charles Simonson
on Aug 25, 2005 at 2:08:34 am
MPEG-2 Program Streams (where the audio and video are muxed) are good for when you don't need to build and burn a complete DVD, and sending just the MPEG-2 movie (for instance, for QCing) where it can easily be played back is more beneficial.
