How to export HD 16:9?
alan
by
on Aug 18, 2005 at 9:13:14 pm
Can anybody give me the steps on how to export a Final Cut uncompressed HD project as an email-friendly mpeg4 file preserving the 16:9 aspect ratio. I can't figure out how to do this without getting the dreaded squished look!
Charles Simonson
Re: How to export HD 16:9?
on Aug 19, 2005 at 3:00:48 am
I assume you want to use FCP to do a direct export. From FCP, go to File>Export>Using Quicktime Conversion... Then select the Options button, choose the MPEG-4 codec from the settings button, and then set a 16:9 custom size from the size button. Can't see any reason why this wouldn't work.
alan
by
on Aug 19, 2005 at 12:03:14 pm
It seems simple enough. I'll try it. Will Compressor give me better results?
