Max video length for cd
Peter
on Aug 9, 2005 at 10:06:35 pm
Hello all,
I am wondering what would be the max amount of video with an audio track be on a cd-rom? Is it the same type thing as a dvd 1 hour before compression type thing??? It is going to be a self start on a pc-mac. I know that leaves it very open to codecs but... Flash or mpeg-1 maybe?
Thanks in advance
Ben Waggoner
Re: Max video length for cd
on Aug 9, 2005 at 11:12:58 pm
The suckier you're willing to make it, the more you can put it on. VCD is one minute of video per minute of audio capacity for the disc. Of course, modern codecs are much better. A good WMV9 or H.264 can likely do a decent 320x240 of four hours or so.
DVD-ROM is much, much larger, of course.
My Book: http://www.benwaggoner.com/books.htm
Squeeze and ProCoder tutorials: http://www.classondemand.net/benwaggoner/
Compression Class at Stanford: http://www.digitalmediaacademy.org/compression.html
Peter
on Aug 10, 2005 at 1:58:02 am
Thak you for the input so you are thinking I could get around 4 hours on a single dvd and still have some quality?
Charles Simonson
on Aug 12, 2005 at 5:12:16 am
At 320x240, 4 hours should be doable with either WMV-9 or H.264. At 640x480, you are looking at 2 to 2.5 hours. If you are targetting a more general audience however, then you are pretty much limited to a codec that you know they will have, which would be MPEG-1. MPEG-1 at 320x240 will look good enough for most projects and can fit around 1.25 to 1.5 hours on a CD, but limiting it to 1 hour would be best.
