pleae advice..quicktime ...png compression
pixel8ted
on Aug 6, 2005 at 8:31:31 am
Hi guys,
Could someone tell me, which quicktime PNG compression setting is lossless, -- with filter setting set to none or set to best
Is this PNG compression quality as good as Animation codec?
Thanks.
Charles Simonson
Re: pleae advice..quicktime ...png compression
on Aug 12, 2005 at 4:55:47 am
Animation is an Uncompressed codec, and PNG is a comrpessed codec, so Animation should be better. If using PNG, you want to use the None filter.
pixel8ted
on Aug 12, 2005 at 8:41:02 am
thanks .
mactrix
on Aug 23, 2005 at 3:47:47 pm
Animation is a compressed codec as well.
The compression is lossless with quality set to 100%.
Animation is 8-bit.
PNG uses a lossless compression no matter which filtering
is used. The prefiltering is just a analyse of pixels for
optimizing the compression.
PNG ist 16-bit in general but the quicktime-codec seems
to be limited to 8-bit
pixel8ted
on Aug 31, 2005 at 7:09:40 pm
Hey man !!Thanks a lot for your Input!
