If there a way to convert a PAL mpeg2 into a NTSC mpeg2 without going to DV first
Benton
on Jul 17, 2005 at 6:14:04 pm
I work at a commercial production company. We are trying to download mpeg2's encoded in PAL off of a site called BEAMTV. I want to use the clips to build NTSC DVD's. The audio on the MPEGs are muxed so use a program called media stream to demux them.
Media stream also offers me the ability to convert the MPEG to DV and then I can use compressor 2 or QT7 (whichever does it better?)to convert the PAL DV to NTSC DV. Then I can make a NTSC MPEG from that. What I want to be able to do, is go straight from the PAL MPEG to NTSC MPEG. Any ideas?
