Compressor 2 Error Message
Jared Kirshenbaum
on Jul 13, 2005 at 3:51:09 pm
Unable to Connect to Backround Process.
G4 17' Powerbook 1Ghz 100GB HD. I was working in FCP5 and went to export using Compressor and then when I went to submit batch, I received that error message.
I couldnt find anything in the archieves here and looking around the net I saw a couple of solutions, none that worked. I reinstalled software (Production Suite) trashed FCP pref. have enough memory where I am storing this media. Disk disk utility, Tech Tools and Disk Warrior. No help.
Can anyone help
J
Charles Simonson
Re: Compressor 2 Error Message
on Jul 13, 2005 at 8:30:08 pm
Check the Final Cut Pro forums on the Cow. This issue comes up often over there (look in the archives as well). I have only experienced this with Compressor 1.2, a long time ago, and the 1.2.1 update fixed it. Also, an update for Compressor 2 was just released just yesterday, so see if that helps.
