Sorenson Squeeze 4.1
Marcelo Lewin
on Jun 17, 2005 at 6:00:53 pm
I'm using Sorenson Squeeze 4.1 to squeeze a file I created in PPro 1.5. How do I tell Sorenson Squeeze that the file (an avi from PPRO) is in 16:9 format. It seems that after I'm done squeezing it down, it looks stretched. I'm squeezing it to an FLV.
Marcelo Lewin
marcelo@thedailyfarce.com
http://www.thedailyfarce.com/
Lisa
Re: Sorenson Squeeze 4.1
by
on Jun 17, 2005 at 6:49:53 pm
In the advanced settings there's an aspect ratio setting. Set that to 16x9.
-Lisa
Marcelo Lewin
on Jun 17, 2005 at 8:20:18 pm
All I see under "advanced" is a "maintain aspect ratio". I don't see anywhere where I can choose 16x9. I'm using Sorenson Squeeze 4.1 Suite.
Marcelo Lewin
Charles Simonson
on Jun 17, 2005 at 10:41:59 pm
Yes, if having the maintain aspect ratio button checked is causing issues, then uncheck it. Or vice versa. I imagine your source is anamorphic, and this will cause Squeeze to encode to the incorrect square pixel format sometimes.
Marcelo Lewin
on Jun 17, 2005 at 11:02:57 pm
I'll try that. Thanks.
Marcelo Lewin
