Ben Waggoner on Digital Production Buzz tonight
Ben Waggoner
on May 26, 2005 at 9:24:35 pm
Folks,
I'm a guest on The Digital Production Buzz tonight, 6pm PST, talking about the "compression economy."
http://www.digitalproductionbuzz.com/LiveThisWeek/
Feel free to tune in, and chat some questions in. I'm sure QuickTime 7 and H.264 will be discussed at length.
My Book: http://www.benwaggoner.com/books.htm
Squeeze and ProCoder tutorials: http://www.classondemand.net/benwaggoner/
Compression Class at Stanford: http://www.digitalmediaacademy.org/compression.html
David
the World's Greatest Compressionist
on Jun 5, 2005 at 12:23:14 pm
Ben,
I suspect you're the only person in the world who knows the answer to this problem . . .
As noted elsewhere, Tiger10.4.1/Squeeze 4.1/QT 7.01 results in very contrasty, unacceptable results in Mpeg 1 and H.264 encodes.
1. Is there a fix?
2. Do you suppose the fix is far off?
I'd ask Sorenson but thus far they've been incredibly lame. Unknowledgable tech support.
Thanks for any info.
David
Charles Simonson
Re: the World's Greatest Compressionist
on Jun 10, 2005 at 1:04:24 pm
David, I'd suggest taking a look a Popwire Compression Master 3.1 for the above formats. CM's AVC output is really amazing (about 15% better than Squeeze IMO), and their MPEG-1 encoding has improved quite a bit as well (now about 30% better than Squeeze). If there is a bug with Squeeze and Tiger, I wouldn't hold my breadth for a fix. Popwire on the otherhand has excellent support and will work with you one-on-one to make sure there is fix relatively soon if you discover a bug. And CM 3.1 does take advantage of some of the underlying features Tiger brings, so there is less of chance of Tiger specific bugs being discovered.
