compressing to QT 6.xx instead of QT 7- HELP
tom adams
on May 19, 2005 at 4:45:50 pm
I'm having major troubles having a client using a PC to view files that I'm compressing from my mac. I know it's the age old problem...but I need a solution today!
I can't export (from FCP HD or QT7Pro) as QT7 and have the client dowload apple QT player because there is NO QTplayer7 for windows YET.
I can't compress to a WMV file becasue I'm using the popwire quicktime export plugin for mac and that loses audio sync...known problem acknowledged by their support team.
HELP ANYONE? is there a way to have QT export to qt 6.xx?. I also have discreet cleaner 5...but that sucks and I'm not sure if it will export to QT7 or QT6.
solution anyone??
Ben Waggoner
Re: compressing to QT 6.xx instead of QT 7- HELP
on May 22, 2005 at 1:37:24 am
The Quick file format hasn't changed in years. You just need to make a file with codecs compatible with the Windows version of QuickTime. Use either Sorenson Video 3 or MPEG-4 Part 2 (not H.264) for video, and MPEG-4 AAC-LC for audio.
My Book:
Squeeze and ProCoder tutorials:
Compression Class at Stanford:
© 2018 All Rights Reserved
