mpeg 2 aspect ratio
mark
mpeg 2 aspect ratio
by
on May 16, 2005 at 11:44:13 pm
hello,
I'm using cleaner 6 and i'm doing a test. We're editing a project in 792 x600 and when I try to make an mpeg2
file it won't let me do a manual aspect ratio. It says that it can't go higher than 420 height wise. Any thoughts?
thanks
mark
Ben Waggoner
Re: mpeg 2 aspect ratio
on May 17, 2005 at 5:34:55 pm
Cleaner 6 is hopelessly broken when it comes to MPEG-1/2 encoding, so I don't recommend you use it in any case.
However, you're trying to make a HD MPEG-2 - SD maxes out at 720x576. For HD MPEG-2 on the Mac, check out Main Concept or Squeeze 4.1.
My Book: http://www.benwaggoner.com/books.htm
Squeeze and ProCoder tutorials: http://www.classondemand.net/benwaggoner/
Compression Class at Stanford: http://www.digitalmediaacademy.org/compression.html
