Any experience in encoding for Mantis MC?
Dan Warvi
on Apr 12, 2005 at 2:16:30 pm
I have to encode a 2 1/2 min presentation cut in FCP at 1080i for a Mantis MC box just installed at a local museum. They've never used the thing before, and have no idea how to encode for it.
Anyone have a cookbook for this box?
Dan Warvi
After Effects, Avid, Curious gFx, Broadcast Systems & PC as nec
Daniel_l
Re: Any experience in encoding for Mantis MC?
on Apr 12, 2005 at 3:29:25 pm
Dan
It accepts MPEG-2 (ATSC). I think Popwire Compression Master can handle the job, Apple Compressor can't.
DL
charles simonson
on Apr 12, 2005 at 4:00:53 pm
If HD MPEG-2 encoding is your primary goal and concern, then bar none, the MainConcept Mac encoder will do the job, or Canopus ProCoder 2 on the windows side. Compression Master 3 currently has a limitation on output limited to either the same as source (up to 1080p), or if scaling is involved, then 1200x900. This should be fixed shortly though.
