Popwire not working in Cleaner
Dave
by
on Apr 9, 2005 at 1:56:00 am
We can't get the Popwire wmv plugin to work in Cleaner which is the latest version. Anyone able to use this with Cleaner? One file never finished and the second one came out 100 plus megs for a file that was 19 megs using Cleaners wmv 7 codec.
Dajen Productions
Santa Barbara, CA
G5 Dual 2 Gig - AJA IO
Huge 1.2 Raid
FCP 4.5-OS X 10.3.5-QT 6.5
Charles Simonson
Re: Popwire not working in Cleaner
on Apr 9, 2005 at 4:36:06 pm
Yes, the Popwire component should work fine in Cleaner. One thing to note, make sure you create an entirely new preset rather than build off an existing one when using the settings. This is an old bug in Cleaner that occurs with practically any new codec beyond the default shipped. Second thing to note is that the component is either single-pass QUALITY-based VBR, which means to use VBR, the bitrate can't be set and the quality meter is important; or it is single-pass BITRATE-based CBR, which means the bitrate can be set to a desired output.
Dave
by
on Apr 9, 2005 at 9:24:32 pm
Thanks, we did duplicate the settings and change it. I'll try building from a new setiing.
Dajen Productions
Santa Barbara, CA
Huge 1.2 Raid
