Illustrator Multiple Artboards > AE
Emily Wapling
on May 5, 2011 at 5:37:10 am
I created a document in illustrator with multiple artboards, saved them out individually as their own singular artboards and saved them separately but when i import it into after effects, all the artboards play out in every composition with only the layers of the very first one. Is there a way to fix this???
Dave LaRonde
Re: Illustrator Multiple Artboards > AE
on May 5, 2011 at 2:42:41 pm
Did you create the layers in Illustrator that you wanted to animate for every one of these separate artboards?
And did you import all the illustrator documents the same way?
And are all the illustrator documents in RGB and NOT CMYK?
Dave LaRonde
Sr. Promotion Producer
© 2018 All Rights Reserved
