particular turbulence field affect only xy
Wolfgang Schwarzenbrunner
on Apr 29, 2011 at 9:55:32 am
hi
i am trying to build up some text with relatively large colored particles. the thing is that they should be slightly moving when the text is built up. i tried using spin amplitude and frequency to get this motion. unfortunatly this affects the z-axis to and so the particles pop up when one gets in front of the other and so on.
then i was trying using the turbulence field - but it also affects all three axis.
does anyone know a workaround - or maybe a script to supress position changes in the z-axis of a turbulence field?
regards
wolfgang
Michael Szalapski
Re: particular turbulence field affect only xy
on Apr 29, 2011 at 1:46:53 pm
Create custom particles that are wiggling about the x,y space in the particle precomp.
- The Great Szalam
on May 2, 2011 at 8:33:18 am
wow... thanks - that will do the job... but why why why??? didn`t i came on it for myself ;)....
best regards
wolfgang
