Problem with DoF
Martijn van Moock
Problem with DoF
on Apr 29, 2011 at 9:43:04 am
I'm experiencing a problem in a small composite I'm making at the moment.
The problem is that there are some strange white spickels showup in the windows in the background. When I turn on DoF.
All the layers are switched to 3D.
Here you can see the problem in the video.
Does anyone has an idea how to solve this?
Martijn
Tudor "Ted" Jelescu
Re: Problem with DoF
on Apr 29, 2011 at 12:53:41 pm
This may be caused by the following:
If you have OpenGL on (turn it off)
If you have a 2d layer in between 3d layers.
If you have two 3d layers one on top of the other at the same value in Z space.
Tudor "Ted" Jelescu
Senior VFX Artist
Martijn van Moock
on Apr 29, 2011 at 2:41:50 pm
Tnx!
The problem was the layer at the same Z position!
Martijn
