Perspective Corner Pin without Position keyframes?
wilhelm Hagberg
on Apr 27, 2011 at 9:31:17 pm
Hi
I work with an interactive After Effect / Flash project. I have made a movie in AE with people holding billboards etc onto which interactive data is going to be projected with Flash.
I have tracked my billboards with the Corner Pin Perspective tracker. Problem is, that when I apply the tracking to a solid (from which I will later export data to Flash) it aplies not only Corner Pin keyframes, but also Position keyframes. This doesn't work for me, I need the solid's position itself to be static, the illusion of movement and distortion only being "created" by the Corner pin effect itself.
Any way to achieve that?
Many thanks-
Wilhelm
Tudor "Ted" Jelescu
Re: Perspective Corner Pin without Position keyframes?
on Apr 27, 2011 at 9:52:00 pm
If you track with Mocha then you can export only Corner Pin data.
Tudor "Ted" Jelescu
Senior VFX Artist
wilhelm Hagberg
on Apr 27, 2011 at 9:57:12 pm
thanks. I'm a bit hesitant to involve Mocha since I want to have a simple workflow (sometimes tracking has to be done in comps within comps etc) but if I find no other way I'll try it.
- W
Tudor "Ted" Jelescu
on Apr 27, 2011 at 9:59:25 pm
I believe you will find Mocha to be very easy to work with in any workflow - just track the clip you need, export data and paste to your layer in AE.
Tudor "Ted" Jelescu
Senior VFX Artist
wilhelm Hagberg
on Apr 28, 2011 at 2:15:21 pm
Problem with Mocha, if i understand correctly, is that you have to use it with already rendered files. I want to track items in precomps. Any solutions not involving Mocha?
thanks -
Wilhelm
