Reverse everything without time remapping
Robert Paynter
on Apr 27, 2011 at 9:08:35 pm
Is there a script or shortcut out there to reverse an entire comp without time remapping?
Kevin Camp
Re: Reverse everything without time remapping
on Apr 27, 2011 at 9:16:46 pm
you can reverse keyframes by selecting the keys and choosing animation>keyframe assistant>reverse keyframes, but that's per property, so there could be a bit of work.
however, that means that a script probably could be set up to go through every property and reverse the keys.
you might check at aenhancers.com
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Robert Paynter
on Apr 27, 2011 at 9:26:26 pm
I'll check . To clarify for anyone else though.
i'm trying to get my timeline, layers, and keys form this
to this
Dave LaRonde
on Apr 27, 2011 at 10:18:08 pm
Here's the easy way: nest the comp in another comp. Turn on the Stretch pane, set the stretch to -100, and position it on the timeline as needed. No muss, no fuss.
Dave LaRonde
Sr. Promotion Producer
