TEXT Roll Animation
Dawud Ali
TEXT Roll Animation
on Apr 24, 2011 at 3:39:20 pm
hi guys
Thanks for your time and help
i wanted to animate the date 2001 and evolve it to 2011. i thought i knew how to do this but i can't. the animation i wanted to achieve was
this(skip to 1.02):
this is my fiends piece she's busy working today so i can't ask her direct.
thank you in advance
Brian Charles
Re: TEXT Roll Animation
on Apr 24, 2011 at 7:06:45 pm
You'll need to animate the Character Offset using 2 separate animators, one for the last digit and one for the penultimate digit.
Restrict the range of each animator to a single digit. The penultimate one should only animate when the the last digit turns from 9 to 0.
Brian Charles
Re: TEXT Roll Animation Example
on Apr 24, 2011 at 7:47:44 pm
2244_dateanimation.aep.zip
Dawud Ali
on Apr 24, 2011 at 9:39:57 pm
Thanks for the help but some further question if you plesde.
firstly how do i set the penultimate digit from the animators once i get the character offsets? (i'm very inexperienced with text animation).
secondly how would i apply the 'penultimate digit' for more than one for number. example in a digital clock or airport information boards
Brian Charles
on Apr 24, 2011 at 9:49:46 pm
Please refer to the manual and help for After Effects.
Text animation is controlled by animators.
I assumed you had some understanding of the software.
Dawud Ali
on Apr 25, 2011 at 1:36:44 am
haven't worked much with text animators, v.useful to learn them inside out. guess i need to rush to the manuals
