Trapcode Form particles do not render
Deepak Adhikary
on Apr 22, 2011 at 10:29:33 am
Hey, I'm trying to do an effect where there is a trapcode form shape, and using the audioreact layer, it dances. This piece is 3000 by 2800 particles and it just refuses to render. When I do a ram preview is works, but when exporting it only appears sometimes during the music when it reacts to the audio, but then disappears again. Can anyone help me with this problem? I do not want to reduce the number of particles because I want it to look very fluid.
Michael Szalapski
Re: Trapcode Form particles do not render
on Apr 22, 2011 at 2:07:13 pm
How are you rendering your video?
- The Great Szalam
Deepak Adhikary
on Apr 23, 2011 at 8:11:11 am
I add it to the render queue, and render it as a quicktime. I've tried Matted and unmatted, RGB and alpha, millions of colors +
Tudor "Ted" Jelescu
on Apr 24, 2011 at 10:35:29 am
The only thing that comes to mind is that you should check the visibility range.
Tudor "Ted" Jelescu
Senior VFX Artist
Deepak Adhikary
on Apr 25, 2011 at 6:57:54 am
The visibility range?
Tudor "Ted" Jelescu
on Apr 25, 2011 at 2:35:37 pm
Right above the "Motion Blur" controls you should have "Visibility". There you can determine the range in which your particles are visible.
Tudor "Ted" Jelescu
Senior VFX Artist
