3D text: Illustrator to After Effects
Alp Tekyildiz
on Apr 7, 2011 at 12:35:21 pm
Hi everyone
I'm working on a logo that has some Illustrator 3D effects (Extrude & Bevel) applied to text. I was wondering if there's a way to import or convert that to After Effects and retain 3D so that I can rotate the layers in 3D space.
Brian Charles
Re: 3D text: Illustrator to After Effects
on Apr 7, 2011 at 2:34:17 pm
No. Can't be done with Illustrator 3D, 3D in Illustrator is a "Live Effect", not a 3D Model.
You need another solution, like Zaxwerks Invigorator or a real 3D Application.
Alp Tekyildiz
on Apr 8, 2011 at 8:36:57 am
That's what I was afraid of. Thanks for your reply/
Sekahng Oh
on Jul 24, 2011 at 8:09:17 am
You can use Photoshop's Repousse to extrude/bevel text or selections(both will be rasterized) and import the .psd into After Effects as a comp, making sure "Live Photoshop 3D" is checked.
Then you will be able to rotate 3D in AE.
