HD MTS to SD MPEG2 conversion in Adobe Media Encoder
Eric Garloff
on Apr 6, 2011 at 2:12:52 pm
I am capturing HD video in an MTS format from my Canon HV30 and I need to end up with a high quality MPEG2 SD output for broadcasting.
When I use the CS5 AME preset for MPEG2 I end up with a file running aprox. 6Mbps. (A 15 min file is aprox 475MB) I want to increase the quality of the image, so I tried to adjust the video bit rate target up to 12Mbps and the AME estimated the file size to be aprox. 1.35GB which seems about right to me.
However, when I encoded the file its output is aprox. 780MB and I don't really see an imporvement in video quality over the 475MB file? If I play the original HD footage it looks very sharp compared to this SD output. I have seen much better SD signals on the same broadcast station which we use. How do I improve my video output quality in the MPEG2 SD format?
egarloff
Dave LaRonde
Re: HD MTS to SD MPEG2 conversion in Adobe Media Encoder
on Apr 6, 2011 at 6:32:57 pm
[Eric Garloff] "I am capturing HD video in an MTS format from my Canon HV30 and I need to end up with a high quality MPEG2 SD output for broadcasting."
Then you should be looking at Telestream's Episode Pro. Quit trying to fart around in AME.
Dave LaRonde
Sr. Promotion Producer
Eric Garloff
on Apr 6, 2011 at 6:55:17 pm
Mr LaRonde
Do you know of any sample files so I could see how much better the final output is in Episode Pro as compared to AME?
Dave LaRonde
on Apr 6, 2011 at 8:21:39 pm
Most broadcast MPEG 2 specs include a bitrate. You'd need to check your particular delivery specs.
The maximum bitrate for a DVD (also MPEG2) peaks at something like 8 MB/s. I'm pretty sure a lot of satellite or internet spot delivery services call for MPEG2 files at something like 35 MB/s, which Episode Pro can knock out all day.
If Adobe Media Encoder can do that -- not just encode at a DVD bitrate -- that's great; you'll save yourself a ton of dough... but I haven't checked if it can.
Dave LaRonde
John Fawcett
on Jun 1, 2011 at 2:00:17 pm
I have tried to convert using several programs but the beat I have found believe it or not is Windows Movie Maker and convert to .wmv files
