Adjust Layer Sizes?
Daniel Boyland
Adjust Layer Sizes?
on Apr 6, 2011 at 6:24:33 am
Hello
I recently made a project in After Effects with a very large image. Unfortunately my computer's reasonably slow and I wasn't able to render it. I tried decreasing the comp size, however this meant I also had decrease the size of my layers. The problem was, there were a lot of them and with anchor points all over the place, scaling down completely messed things up.
I was wondering if there's any way to decrease the size of all the layers while keeping them all relative to each other so the outcome looks exactly the same as the original. (Pre-composing doesn't work as the data from the orignal image's size is still there)
Tudor "Ted" Jelescu
Re: Adjust Layer Sizes?
on Apr 6, 2011 at 9:47:47 am
Use the change composition size script (under File/Scripts)
Tudor "Ted" Jelescu
Senior VFX Artist
Daniel Boyland
on Apr 6, 2011 at 10:55:30 am
