Still a Particular jagged lines problem
Nate tull
on Mar 25, 2011 at 4:52:35 pm
Im using particular to make these streaks of light. I have them attached to a light that I keyframed from one point to another (just 2 keyframes). Then pulled the bezier handles to make the straight line have a bit of curve to it but when my particular streak follows it it makes these rude looking straight lines thru the curves. how can I fix this? thanks so much ppl!
Found this post tip but cant find "Position Subframe". Go into the "Position Subframe" and try "10x Linear" or higher.
N8Pro1
Tudor "Ted" Jelescu
Re: Still a Particular jagged lines problem
on Mar 25, 2011 at 5:49:21 pm
What version of Particular are you using? To my knowledge only v2 has that option, so if you're on a previous one you can look long and hard for it and you won't find one.
Here's a link to a great tutorial that describes the option in Particular 2:
http://maltaannon.com/articles/after-effects/particular-2-overview/
Tudor "Ted" Jelescu
Senior VFX Artist
Nate tull
on Mar 25, 2011 at 6:12:20 pm
Its the 1st Particular. Is there anything I can do to get the sharp path lines to be more smooth?
N8Pro1
Tudor "Ted" Jelescu
on Mar 25, 2011 at 6:17:01 pm
Not really, that's why the Subframe option was included in v2.
Tudor "Ted" Jelescu
Senior VFX Artist
Cassius Marques
on Mar 25, 2011 at 7:01:34 pm
yes you can... it can track lights with subframe sampling... you can also try to increse your composition's frame rate, and then reimport that into your desired fps (up to 99 i think, so it has a limit too)
http://library.creativecow.net/articles/kramer_andrew/nano.php
that tutorial will explain it to you.
Nate tull
on Mar 25, 2011 at 7:10:15 pm
thanks to you all. you're great & greatly appreciated!
N8Pro1
