Particular jagged lines problem
Nate tull
on Mar 25, 2011 at 3:15:51 pm
Im using particular to make these streaks of light. I have them attached to a light that I keyframed from one point to another (just 2 keyframes). Then pulled the bezier handles to make the straight line have a bit of curve to it but when my particular streak follows it it makes these rude looking straight lines thru the curves. how can I fix this? thanks so much ppl!
N8Pro1
Nate tull
Re: Particular jagged lines problem
on Mar 25, 2011 at 3:39:13 pm
Nevermind. thanks folks!
Go into the "Position Subframe" and try "10x Linear" or higher. Also, make sure that Velocity from Motion is zero, as (for some reason) that doesn't respond to the subframe sampling.
Harry J Frank
Freelance Motion Designer
graymachine.com
N8Pro1
Nate tull
on Mar 25, 2011 at 4:00:37 pm
OK, i hate finding myself blind and...well, Where is "Position Subframe"?
N8Pro1
