Align Text Left Scripting
Matthew Joal
on Mar 18, 2011 at 12:38:45 am
I’m new to scripting with After Effects and I’m having troubles doing the simplest thing. I got most of my program to work just fine, however, when I used the built-in text replace function it changes my text from left aligned to center aligned. I need to set my text layer to left align again after the text it changed.
Can anyone please help me? I know this is very basic, I just can’t find anything in the scripting guide that will help.
My last resort option is to set the anchor point of the text field but I would rather just set the alignment.
Here is the replace function:
replaceTextInLayer(app.project.item(99).layer(8), "Original", "New")
I just want to left align this text layer.
Thanks in advance for your help!
Dave LaRonde
Re: Align Text Left Scripting
on Mar 18, 2011 at 3:14:48 pm
I'm having difficulty understanding why it's necessary in your project to use a script do do this when you can create a text layer using the Justify Left setting, and change the text using Source Text keyframes on the text layer.
Dave LaRonde
Sr. Promotion Producer
Brian Berneker
on Jun 9, 2011 at 1:55:16 am
I have the same problem (right align actually):
I create a text object, set it right aligned and all is well.
I then duplicate the object so that it has the same font, alignment etc., and use an expression to get the source text from the first text object. Once I do this, the new layer suddenly changes its alignment to "centered" and is uneditable!
Solution/Workaround PLOX?
