Change the background alpha color?
Deyan Terziev
on Mar 15, 2011 at 10:00:45 am
Hi
How can I change the AE composition background color to not just be a flat color but to use a footage. So when I render it and import it back to AE with ignore alpha checked to see that footage I have chosen.
Dave LaRonde
Re: Change the background alpha color?
on Mar 15, 2011 at 4:19:08 pm
Sorry, but you can't do that: you can't substitute the background color for a piece of footage. If you put footage in as a background, you will no longer have transparency where you want it.
But you CAN use any kind of footage you want as a background, and before you render turn it off by using the eyeball switch. If you don't turn off the background footage, AE will render it as well.
Dave LaRonde
Sr. Promotion Producer
