Anyone else get this After Effects render glitch?
Peter Dowson
on Mar 7, 2011 at 6:45:40 am
I'm running After Effects CS5 on i7 PCs with a variety of drives and connections and have been getting these random noisy glitch frames in various AE renders since back in CS4.
See attached for a typical example.
They are usually single frames and I may get 1 every 45 secs or so. I've almost learnt to live with them by just deleting the offending frames. I had assumed the drives were getting fragmented, but now have defragged all drives and also notcied the glitches on new drives. I just wondered if anyone else gets this and what I can do to get this gremlin out of my life?!
Roland R. Kahlenberg
Re: Anyone else get this After Effects render glitch?
on Mar 7, 2011 at 7:45:27 pm
This sounds like a RAM/memory issue rather than a drive related issue. The fact that the render errors are at regular intervals should provide such a clue. AE's render engine is pretty bug-free if you do not include the 'out of memory' feature from hell issues that occasioanlly crop up.
Perform a COW Search on how to purge AE's memory during a render. Additionally, such errors are related to the use of a certain plugin(s). See if you can nail down the sucker!
Good Luck!
RoRK
AE Training in South East Asia. AE templates for sale and rental. Click here for more
Spencer Tweed
on Mar 7, 2011 at 7:48:39 pm
Nothing seems to be attached to your post.
I have never heard of the problem, but maybe you would be interested in this:
http://aescripts.com/pt_framerestorer/
- Spencer
Craig Wall
on Mar 8, 2011 at 1:28:02 am
I don't see your sample but I'll say this: I was getting lots of corrupted frames and by doing two things I think (knock on wood) that I resolved the problems
1. In preferences I went down to only using 4 of my 16 cpus/threads and giving everything lots of RAM
2. I went from a storage situation where my drives were quite full to a new RAID with ample room and faster I/O.
Life is full of funny particles.
Peter Dowson
on Mar 8, 2011 at 1:54:44 am
Sorry here is the screenshot:
Thanks for replies so far I'll try em out :)
panos mortis
on Mar 8, 2011 at 9:07:59 pm
same problem to me with A.E cs5. The most weird is that this happens only on my laptop pc, but not on my desktop both with win7 64bit and only from export to AVIs - DVpal.
Peter Dowson
on Mar 8, 2011 at 11:58:51 pm
@ Panos Mortis
Interesting, as this also only happens for me on PAL AVI renders - both DV and uncompressed though.
panos mortis
on Mar 12, 2011 at 5:45:35 pm
peter
i think i found the problem. Try to export the comp, not on an external hard disk as i did, but an internal or other drive with different connection. Its working to me!!!
Rohan Wright
on Feb 21, 2012 at 1:00:15 am
I also found that the issue was external HDD's only.
I have two 4TB USB3 HDD that I store everything on, and this is really frustrating that i have to render then move the files each time.
Chip Simons
on Oct 22, 2012 at 8:43:13 pm
Thanks! I was having the same problem. Rendered to my internal hard drive, problem went away.
Walter Soyka
on Mar 9, 2011 at 2:20:48 pm
If you are rendering with OpenGL, turn it off and leave it off.
If you're using multiprocessing, try turning it off.
Are you using any effects which feature GPU processing?
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
