remove grain with adjustment layer
omid abesta
on Mar 6, 2011 at 9:58:56 pm
hello
I know english a little so answer simple
when I apply every effects to Adjustment layer, lower layer (layers) affects from effect exist on Adjustment layer. but when apply remove grain to Adjustment layer , the layer that is below dosen't change!
why? what must I do?
thank you
Joey Foreman
Re: remove grain with adjustment layer
on Mar 6, 2011 at 10:37:31 pm
Remove Grain defaults to a small region of interest preview. Change the Viewing Mode to Final Output.
Joey Foreman
Editor/Compositor/VFX Artist
Brian Charles
on Mar 7, 2011 at 6:59:25 pm
The Remove Grain Effect does work on an adjustment layer.
Check your preview and noise sample settings.
omid abesta
on Mar 8, 2011 at 12:35:28 am
thank you
but preview and noise sapmle is right.
I apply the same effect on layer, is ok but when i cut it and paste on adjustment layer it dosent work!
can you test it please?
Eric Epstein
on Mar 8, 2011 at 8:04:07 am
Testing in CS5, Remove Grain works on an adjustment layer.
I don't know what would cause it to not work.
Have you tested the adjustment layer with other effects, just to make sure it isn't somehow disabled?
omid abesta
on Mar 8, 2011 at 7:38:41 pm
Hello
i used cs4 in vista. then i went to windows 7 and cs5. the problem was solved!
thank you every one
