3D object following an expression path
Fabrice Ducouret
on Mar 4, 2011 at 5:46:32 pm
In AE, I have an animation with expressions paths with effects (particular smoke, sparks...)
I would like to attach a 3D shape of a rocket that I made in photoshop to one end of the expression paths.
The 3D layer seems to be ok, but I'm not sure how to attach it to the path. Or make it go along the expression path.
I'm still new to AE but let me know if you have an idea.
Many thanks :)
Brian Charles
Re: 3D object following an expression path
on Mar 4, 2011 at 7:53:11 pm
If you used a null or light to animate the particle path in Particular you could just parent the layer to that.
