Swirl actor in scene efect ?
Eric Levy
on Mar 3, 2011 at 1:06:44 am
I would like to know how to make a swirl with 2 dancers in AE.
My client shot some tango dancers and he wants some sort of swirl effect as the couples body moves in circles.
Not the whole image swirling but just the dancers with some swirling fades or whatever its called.
Csn anyone help me or suggest ?
I imagined using 2 layers of the same image and masking the couple out on the top layer and adding a swirl effect with blurr ......wouldmthis be the best approach ??
Tudor "Ted" Jelescu
Re: Swirl actor in scene efect ?
on Mar 3, 2011 at 12:23:45 pm
I would use Particular to create some cool swirls on the dancers. You would have to animate lights in 3d space to match the rotation perspective for the dancers, use that as a particle emitter, play with the visibility for the particles to make them disappear behind the dancers and create the "iPod commercial" light streaks around them. Once you have those (using multiple emitters/lights) you can play at will by creating glowing light swirls (in 32 bit project)or just use them to create a alpha layer that you can use to comp the layer on top of itself while using Time effects on it (Echo).
Tudor "Ted" Jelescu
Senior VFX Artist
Michael Szalapski
on Mar 3, 2011 at 2:21:40 pm
There are some decent tutorials for light streaks out there for Particular.
Here's one for CC Particle World (in case you don't have Particular):
Here's a really old-school method that doesn't use particles at all.
Now, this is all assuming that this is the kind of look he's going for...
- The Great Szalam
© 2018 All Rights Reserved
