Calibrating a Monitor
Eddy Rose
on Feb 28, 2011 at 1:32:18 am
So what is the best way to calibrate a monitor for motion graphics type work? Also what do I do if I have two different monitors and one is really hot and the other really cold?
Michael Szalapski
Re: Calibrating a Monitor
on Feb 28, 2011 at 4:45:01 pm
Calibrate both monitors and they'll both be the same.
There are several different devices for monitor calibration that would do the trick pretty well - seeing as that's what they're designed for. Spyder's the one I've heard the most about.
Or you can go the poor man's route and use a THX optimizer. Most THX certified DVD's will have it on there. (You may need to get the blue filter glasses, they're cheap from THX.)
Or you can load a reference image onto both monitors and match them by eye.
Best option would be a professional calibrator, of course.
- The Great Szalam
