Random Artifacts on video
David Biederbeck
on Feb 14, 2011 at 5:41:46 pm
Any ideas of what this could be?
I've turned off all layer styles, in comps and pre-comps.
cs4 - 12 mb ram
Walter Soyka
Re: Random Artifacts on video
on Feb 14, 2011 at 6:03:11 pm
Are you using Optical Flares? If so, do you have the latest version? What happens if you uncheck Use GPU?
I usually render to image sequences, and when I get glitchy renders from a third-party plugin, I just delete the dirty frame and re-render it.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Tudor "Ted" Jelescu
on Feb 14, 2011 at 6:25:25 pm
I think Walter is right. It looks like an OpenGL issue. Try rendering without OpenGL.
Tudor "Ted" Jelescu
Senior VFX Artist
David Biederbeck
on Feb 15, 2011 at 3:55:37 pm
It was a layer with lots of vectors on it set to soft light in the comp, and the comp set to add. I don't know why it was doing this, but as soon as I changed it, it worked.... strange.
